ka24E ECU pinouts
narshell
Car: drag racing
I just bought an S-AFCII but I don't have the ecu pin-outs for the KA24E to do the install.Who can help me???
DAN510
What pinouts do you need?? ie. injector drivers tach line etc...
Maybe I can help....
narshell
Car: drag racing
Don't have any info at all the ecu (ka24E), can't install the S-AFCII
DAN510
Do you have the info/diagram for your S-AFCII???
Cuz if you don't, I can't help....Sorry
DAN510
narshell
Car: drag racing
I have the instructions, but my engine is not listed in the manual.The KA24E is not listed in the manual, now I don't know if I should refer to an other engine for this hook-up?
180fan
Car: 89 fastback
KA24E = N3-B with HW-5
AFC II wire colorsred = powergreen = rpmpurple = knockgray = throttlebrown = groundblack = groundyellow = airflow outputwhite = airflow input
note: brown should be closer to the ecu than black.
If you're looking at the ecu from the back where the pins poke, it breaks down like this from left to right: 16, 14, 16, 18 (# of pins)
1st bank (16 pins) = no wires to add
2nd bank (14 pins) = upper row, third from the left, that's RPM
3rd bank (16 pins) = top row 2nd pin from left, that's airflowtop row third from the right, that's throttlebottom row 5th from the left is knock (not applicable in 24E's case)
4th bank (18 pins) = top row, right most position is groundbottom row, second from right is power
The airflow wire you have to cut and from the signal, hook it up to the white wire, then to the ecu, the yellow wire.
Hope that helps.
narshell
Car: drag racing
thanks Bro!!!
