I want to change all hoses and vacuum lines but it seems you need a 5 year old to do it. There is no room in certain places.
1. How can you get to the other end of the hose from the IACV? It goes down and disappears from view.
2. I removed the BPT and tried to get to the large hose going to the Air Regulator but couldn't get near the clamp with a screwdriver. Is there some trick to changing that hose?
3. There is a coolant hose going to the ECCS--how do you get to the other end of that hose to change it?
4. And how do you get to the EGR bolts? The firewall is right next to it.
