If you have a Nissan power steering pump that is not in use, this might give you an idea as to where it might belong.
I decided to take a Datsun 510 and make a Ka24E fit as low as I could for nice center of gravity, but also towards the fire wall for behind the front wheel handling. The result of this idea came clearance issues among other things. My solution was simple. Take the system I had initially and replace it with a Dry Sump system.
After researching for about a month, I found that no one has taken a vane style PS pump and trusted it with a dry sump set up. I don't blame them, because the PS pump usually already has a job to do, and it does a great job at that. I on the other hand, had no power steering box because my very light 510 just doesn't really need it. I like to relate my car setup to the McLaren F1 in the PS area lol.
The traditional gear type pump has drawbacks that the vane style pump does not have. The vane style is more efficient and has less wear for a more reliable flow. The fins supply constant pressure with very little power loss through the cycle. A gear pump does wear more and is less efficient. Gear pumps cost less to maintain, but need more maintenance. The gear pump is also more compact making it easier to mount. Vane pumps tend to be bulky and harder to mount. My mind was made up.
The system I used consists of:
The oil container with according outputs and inputs.
The AN fittings, -6, -8, -10.
Oil filter distribution block
Engine block input/output plate
hydraulic parker hose 300psi hose
A lot of AN fittings of all types.
Stock KA PS pump
PS adapter to -6
Flow regulator for the feed
Stiffer spring for PS pump relief Valve.
~$300 for the setup
I started with plumbing the whole system to see where things fit. After the lines were routed, I used a drill to turn the pump without the belt on it to see if I got pressure. I did, and the flow was the same, if not more than my oil pump. I need to do an exact flow rate when I have time, because I know flow and pressure are two different things.
After I got the guts to start the car on the system, I noticed that when idle, I was at 30psi, and when revving past 2500, I got a drop in pressure. This was the relief valve kicking in. I used a stronger spring to fix this. Pressure increases with rpm at 10psi per 1k of rpm. Idle is around 40 psi cold on light weight oil.
I will be adding pictures soon. Here is a video for now
https://www.youtube.com/watch?v=VpBn-5Fpg6Q
