breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Mon Feb 13, 2012 1:33 pm
I have a 1989 240sx with a KA24e, stock motor with a 5speed swap.
1) I got the car running after the swap after I fixed a vac leak where the lower and upper intake mate.
2) It drove fine and was torquey(guessing timing was slightly advanced) but I could hear chain slap in the front cover.
3) Replace timing set with a mechanic who knows what he is doing. Reset timing to stock and it drove okay but wasn't as torquey.
4) The next day I was driving home after getting tires. car started bogging and losing power, flooring it in 2nd or third gear only had me going 30MPH until it died on the side of the road.
Now when I start, it fires then dies and only stays running if I mash the gas all the way in and out repeatly. No idle.
Tried known good MAF and IAT, no change.
Getting spark on new plugs and wires.
Injectors pulse good
Sprayed around bay with carb spray, no idle change.
Idle screw adjustment does nothing
TPS is dead on, .5v to 4vWOT
Tried different ECU
Battery good
Starter good
Alt seems fine
Haven't tested fuel presurre yet.
Only video on youtube that even seemed to apply to these symptoms is the one talking about the big tub on intake that goes to the brass tube that runs parallel to the aicv and the other idle thing back there. but once again I sprayed carb spray and no vac leak.
Would either of those cause the car not to see throttle input and cause no idle?
I need to drive this car soon, Paying insurance for nothing sucks.
My last resort will be to jack out the motor and replace all hoses and delete all emissions.
I know it has a small leak at the top of the rad from a messed up tab.
I can't think of any other issues that would do this, maybe no fuel pressure.
I am open to any thoughts from the NICO crowd.
