ka24e distributor
Luciddreamer117
Car: 95 Extended cab Hardbody
I picked up 95 hardbody, and noticed the engine was swapped with a 96-97 block which has the different timing cover. Question is will the obd2 distributor work in the 95 which had the obd1 distributor?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Well the Hardbody trucks never had OBD1. And no the distributor from the OBD2 96+ trucks will not fit the older trucks unless you have a really late 1995 that could have come with OBD2.
Luciddreamer117
After a lot of late night searching I figured it would not work with the 96 dist. I am thinking of just drilling and retapping the timing cover so I can use the 95 dist. And not change the timing cover.
abunaitoo
Isn't the distributor in the block on a K24E?????
abunaitoo
Sorry, I was mistaken.
It is on the timing chain cover.
I noticed that 1995 and earlier has a different distributor mounting bolt pattern than 1996 and newer models.
david29
Car: 1987 Nissan Hardbody D21 King Cab 2wd
It sucks but youd be better off replacing the timing cover to use the correct dizzy.
