240tunerguy »
https://forums.nicoclub.com/240tunerguy-u43309.html
Mon Dec 18, 2006 9:55 am
i have a 90 240 with the ka24e. i pulled the motor to put in a new clutch, reseal the oil pan and the timing cover. after pulling the timing cover i noticed the timing was off a few teeth so i put it back to where it is supposed to be. put it all back together, readjusted the oil pump, dropped the motor in etc. started up but has a real bad misfire in cyl. number one. i put a new cap and rotor, plugs and wires, new injectors and rewired inj number one. i can pull the spark plug and injector clip on cyl one and nothing happens. i didnt mess with any internals or remove the head. im stuck and need my car back. the car ran great before i took it apart. any ideas will help. from one nissan fan to another, thanks.
Modified by 240tunerguy at 12:48 PM 12/18/2006
Modified by 240tunerguy at 12:49 PM 12/18/2006
