deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Oct 09, 2005 7:12 pm
ka24de frontier timing cover will only fit frontier block. It could be slightly modified to fit onto a sohc block but will offer no advantages as far as mating to a dohc head is concerned (assuming your wanting to use a 240sx head). You would still have to do the same amount of fab work.
Now if you were to use a frontier head, that would be a different story in the modification department (closing the gap). The frontier cover would still yeild little advantage and you would want to use the sohc cover (easier).
*NOTE: Frontier ka24de has sohc style oil pump/distributor (slim upper/lower), just because it is ka24de does not mean it will mate the 240sx de head to the sohc block.
