KA24e-DE head swap, ASAP!!!!
SR22DET
Car: cars cars girls cars
hey guys I was taking off my exhaust mani today and found a huge crack in one of the exhaust ports so i have a choice buy an E head or try to mount on the DE head from the 95 ka24de thats in the garage.. anyway i tried searching because i remember like 2 weeks smug510 and glacier985 did the swap but now the pic's dont show for some damn reason and i cant find half of the postings so i was wondering if somebody could do a little write up or help becuase i need the car to start working within the next 2-4 days, umm also like a little parts list all i have is the longblock KA24de so no i dont have the Mani's this is what i thought of so far
parts list:exh and int manifoldswiring harnessecu???valve cover (i need one)
ANY HELP WILL BE VEEEEEEERRRRRRRYYY APPRECIATED!!!!!
DaydreamDrifter
Car: 90 240sx 00 Altima
hey ugh, 1'll finish up my write-up and try to have it posted sometime tomorrow.
I have a Word document How-To, does it need to be hosted?
http://www.imagestation.com/al...40847
Modified by DaydreamDrifter at 10:11 PM 2/13/2005
Dattebayo
DE head WILL NOT work with E block, and vice versa. There is lots about this in the archives if you use the search button.
Are you guys serious about this? Because i know alot of people tried this before and were told the coolant ports would not match between SOHC and DOHC.
SR22DET
2BN_S13 wrote:DE head WILL NOT work with E block, and vice versa. There is lots about this in the archives if you use the search button.
it seemed to work when smug510 did it and glacier985 ...
SR22DET
DaydreamDrifter wrote:hey ugh, 1'll finish up my write-up and try to have it posted sometime tomorrow.
hey how does your car run... that is if you got it running yet, i want to prove my dad wrong and also beat my friends camaro... they both dont believe it can be done and work and also my friend is cocky about his camaro... v-6
SR22DET
by they way thanks a lot for the kick aS$ pics daydreamDrifter
DaydreamDrifter
i may be able to pick her up this afternoon of tomorrow. I have to get a mechanic to fish timing and diagnose a couple of things; a ****ing ground and a starter that need to be kicked. Open manifold was bad ***, it sounded like a ****ing V8. Look, I will post my how to in my next post and if moderators deem it neccesary to repost a new thread and sticky it.
DaydreamDrifter
I will not be held responsible for you screwing up your own vehicle. Or for anything you consume by the information I have provided.
Head Swap How-To
SOHC motor converted to DOHC head with SOHC short block.
Pictures to guide are at http://www.imagestation.com/me...ifterInternet FSM’s available at http://www.zeroyon.com/TheSite/techservice.html
Things you’ll need…• Factory Service Manual (FSM) & Nissan Parts Dealer• DOHC head, intake manifold, exhaust manifold & down pipe, and Top Timing Chain Cover. Also top radiator hose and intake plumbing. Be sure that all vacuum lines intact and accounted for. Make sure to have brake booster vacuum line and fuel lines going down from fuel rail or else you will have to replace it. And it doesn’t hurt to have the DOHC’ s coolant nipple from the lower timing chain cover. Cut off injector plugs from the DOHC harness.• SOHC - ECU• Head Bolts• Head Gasket• DOHC Timing Set (Chains, Guides, & Tensioners )• Special Tools: Pulley Remover, Torque Wrench, Sheet Metal Snips, Bench Grinder, Reciprocating Saw ( Saws-All )• RTV Sealant (look in FSM)• Sheet Metal about 22 gauge• ½ ounce Marijuana, http://www.thehun.net , Water, CD Player with Bob Marley, 20 Shrooms• Maintenance Items: Spark Plugs, Spark Cables, Coolant, 4 quarts oil & filter (cheap oil to be able to clean your system out after running)• Car Ramps or Car Jack and Jack Stands• Wire Connectors (of your choice) • (May not be needed. Step 23. ) 3/8” X 3/8’ Brass Barb to MIP adapter (Watts Parts No. A294)
Take a look at the routes of coolant, fuel, and vacuums on the SOHC engine while it is still virgin. I will describe my emission control removal in notes of the article. Because I removed all emissions I really won’t be able to help with other vacuum related questions. Car needs to be on ramps with a block to stop rolling or on jack stands for the exhaust side of the swap.
Steps1. Drain coolant and crank engine for thirty seconds or so to push rest of coolant out. May as well flush it right?2. Drain oil and leave oil filter on as it is a lot easier to get to with the head and manifold off.3. Disconnect battery and hell, pull it out, the battery tray is a good tool box. HAHA I’m so funny.4. !!!!!!! Remove top and bottom radiator hoses, intake plumbing, fan shroud, clutch fan.5. If you are able to get the exhaust manifold along with the down pipe then just cut your existing SOHC down pipe in roughly the same area with Saws-All. Then just unbolt the EGR tube or cut if you don’t care about it. Now just unbolt the manifold from the head as described in the FSM and pull out the manifold plus cut down pipe. *NOTE: SOHC down pipe does not work with DOHC manifold.6. Now the fun part ELECTRICALS ! It is your job to find all grounds and wire connectors. I had to use a small knife for the pins that hold connectors together. Find a way to mark connections or just take a lot of pictures.7. Use some vise grips on the fuel line that comes from the metal tube from below unless you like to sniff gas. Remove the lines at the top end but do be careful as they tend to dry rot and they are a ***** to get off anyhow.8. Remove vacuums that connect to the intake manifold, so that it will be easier to install the new stuff. Now marking and labeling vacuums sucks because no tape wants to stick to them. This is where memory, pictures, and an FSM come in hand.9. Remove the throttle cables from the throttle body (two if you have cruise control).10. Marijuana break: 4 minutes and 20 seconds. Wash hands before lighting especially if you have gas on your hands.11. Use wrench to turn motor to first cylinder TDC as described in FSM.12. Now unbolt the valve cover and marvel at what you have started. Now is a good time to find a way to keep up with different bolts, such as a hobby tray with dividers.13. Remove the bolts that connect the SOHC head’s cover to the bottom timing chain cover.14. Remove the timing chain gear from the head as described in the FSM.15. Unbolt the head as described in the FSM.16. Remove with a friend and place under your pillow and maybe the EBay fairy will get off their lazy *** and give you some money for it.17. Remove all belts and drain the power steering fluid before removing the power steering pump. *NOTE: Power steering will not fit after head swap.18. Remove lower timing chain cover as described in the FSM and don’t forget about the bolts that go through the oil pan in to the cover either. Also be careful not to mess with distributor.19. Remove timing components.20. Test fit passenger side timing chain tensioner by installing it and putting lower timing chain cover onto block. You should be able to see one of the angles that it needs to be ground down on. It will have a substantial amount of metal removed but don’t worry.21. Either have the top cover’s distributor whole welded up or plug somehow. I will try sheet metal and RTV sealant. And so far so good!22. Replace oil filter now before you forget.23. Also with the head off, you need to begin piecing together a PCV line, unless your DOHC line will work. This goes from the lower timing chain cover to the tube that connects each intake runner, on the bottom of the manifold. Pictures available. Each end of the hose will have to be different sizes. I hacked up some emission control hoses and have this working. See pictures.24. Replace the coolant nipple on the SOHC’s lower cover to the DOHC nipple, requires RTV sealant. I’m not sure it an OEM hose will work afterwards, I bought some instead.25. Place head gasket on and with the gasket extends over the block, in the front, cut it off as it will not fit between the two covers. 26. Place head gasket down and with a friend put head, intake manifold, and exhaust manifold onto the block and be sure that the nipples on the block are in line with the appropriate holes of head.27. Follow FSM directions for instillation of your new head bolts. 28. Now with head in place and your lower cover fitting over the ground down tensioner, put the front cover onto the DOHC heads front and you will now see why you need to cut the head gasket and why you have to make a sheet metal adapter for the two covers to work properly. 29. Use common sense and help with my pictures to make an adapter. Take your time and don’t eyeball everything either, use a tape measure and sharpe marker.30. It is hard to get the top cover in place with the adapter there but its possible, line up the studs on the head with their holes on the cover; with a towel and hammer tap each side equally; going side to side until it is flush with head.31. Remove two covers and install the rest of the timing set as described in the FSM. For cams’ TDC setting go to: http://jimwolftechnology.com/w...E.PDF32. !!!!!!!! Cover instillation with RTV sealant.33. Install valve cover as described in FSM. Pour some oil onto cams for initial lube upon startup.34. DOHC injectors require a different wiring harness connector than those of the SOHC. So I cut off the SOHC injector plugs and wired in the DOHC injector plugs. The red wires are a different gauge than the coupled wire. Match the wires and connect them. Do it the right way and not with just electrical tape, damn man. Rest the cut plugs on the injectors to be sure of wire length when connecting. *NOTE: SOHC wiring harness has a plug in-between cylinders 2 & 3’s injector plugs, so be careful not to cut that one off. I have no idea what it goes too!35. I bought two cable holders and mounted them at the two available holes on the fuel rail to keep the wiring harness off of the valve cover and to keep the connections from being pulled on.36. Connect remaining harness connections, fuel lines, and vacuum lines. Don’t forget about the big ground going to the intake manifold like I did. 37. Install crank pulley and put on all belts, as told by FSM.38. Install radiator hoses and the heater core line (to the firewall).39. Throttle cable has to cross the valve cover to reach
*NOTE: Cruise control cable will have to be lengthened.40. Fill with oil.41. Reconnect battery and pray.42. Try to crank it. 43. Now install coolant.
[email protected]
crzycav86
Car: 93 Nissan 240SX KAT
I smell a sticky....
Good job y0.
Dattebayo
Sounds like a mickey mouse job to me.
I dont wanna seem like im stealing your fire, but i dont see how this can be supported by the forum, judging that important parts will be exposed and you cannot run power steering, eic.
SR22DET
thanks a lot again, i'll get to it ASAP but i got a few questions," • SOHC - ECU " wouldnt you need the DOHC ecu? did u get a DOHC wiring harness? are the sohc injectors same as dohc
DaydreamDrifter
Using SOHC ECU, and harness, although i wired in the DOHC's injector plugs. No, the plugs and injectors are different going from SOHC to DOHC. The SOHC MAF has a different plug than that of the DOHC and well it has been running already.
silvia200zx
Car: Working on my car.
Just a quick question, which distributor do you use. DE has dist. in head. E has dist. in block. Just hook 'em both up and pray one works? CAN'T DO IT. Sorry.
SR22DET
just a quick (stupid 16 yr.old) question: it would raise my compression to like 11.2 or 11.7 :1, right? does that mean that i have to use 91 octane from now on?
DaydreamDrifter
Look, I myself will be testing this all out soon, but some say 93. Dependent upon when your car was made, is whether you will have 11.1 or 11.7 CR. Someone correct me if I am wrong. But it is explained in glacier985's Head Swap thread.
oluazkfz
Car: 90 240sx
hey just wanted to know how much did u pay for the swap and how much do u think it will cost for parts?
DaydreamDrifter
call your junkyard
SonyPete
Doesn't look too bad at all just the metal sheet to cover the head gap. How do you plan on keep that sheetmetal pressed aginst the bottom of the cover??, you could use nuts and bolts to keep it pressd up into cover. OR even have metal welded to the cover to make it cover and even tap it with holes and make it look stock
DaydreamDrifter
the metal is too thing to tap.A thick bead of RTV sealant works fine.
