KA24E cutting out...need advice
piggycoupe89
Car: 1989 240sx pignose
my coupe cuts out at 4500rpms in 3rd and 4th gear under acceleration any suggestions? Ive replaced the plugs and wires and it still happens idk what to do. It only does it for a second then i shift and its fine.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you checked for any disconnected or damaged vacuum hoses? Does it do it at any temperature?
ka24hardbody
Car: 1990 Nissan Hardbody D21
Mine cut out for the longest time and could never figure out what was wrong with it. And it turned out it had bad gas. Id make sure you dont have bad gas or need a new fuel pump strainer before tearing stuff apart.
Tw1tCh_F0_5hIzZlE
Car: S13 CoUpE
i actually had somewhat of the same problem the last coouple of days and i replaced my plug wires ,cap and rotar, replaced my exhaust manifold gaskets and had to rethread my 4th spark plug hole and the same thing happend to me when i accelerate my car lost power and the last thing ended up being my fuel injector connections and the wires for the fuel injectors so i cleaned my connections and replacing my wires soon
Tw1tCh_F0_5hIzZlE
Car: S13 CoUpE
Reverend D wrote:Have you checked for any disconnected or damaged vacuum hoses? Does it do it at any temperature?
^^ this also helps out alot
piggycoupe89
I think it is the injectors actually cause ive already replaced one due to corrosion in the connector. The other 3 werent bad at the time but guess they are now. Damn.... they are so tedious to clean too. thanks though i wouldnt have even thought about it till now.
Tw1tCh_F0_5hIzZlE
Car: S13 CoUpE
you can pick up corrosion spray at any automotive store and spray it in to the connection (witch i did) and it started to work fine again
