rocksteady_racer »
https://forums.nicoclub.com/rocksteady-racer-u29694.html
Wed Jul 27, 2011 10:45 am
It's a real aeromotive with a liquid filled gauge, it's good. I think I figured it out. I'm going to double check. But it reached operating temperature in like 10 seconds and on all the other symptoms, it was running mad rich before I fixed it up. So my theory, the cat is severly clogged. That and probably clogged fuel filter too, might as well replace it just in case.
Also the timing was a little off, gotta retime it again, apparently it shifted a little when I was aligning the pulley. I cranked the distributor to the right and it started to lighten up, but it still is idling at 650, until you disconnect the battery then it jumps up to 750. It's supposed to idle at 650 then jump up to 1100 when you disconnect the battery right? It was doing this before I mechanically timed it (idling at 650, won't rev past 2500 til it's warm than not over 4000). so I assume there is some other problem cause I timed the engine almost perfect mechanically I thought (the cam pin was straight up, didn't mess with the chain, and the pulley was set to TDC. also the oil pump was installed correctly (straight up and down backwards D). It still wont rev past 2500 now, but that's better than before, so I'm going to try and time it again I guess. I might as well check the compression while I'm at it cause it's odd. First time timing an engine so at least it ran I guess. But it was doing this before I retimed it, thought it was the coolant temp sensor I guess not, running mad rich all the time. And the chain was ridiculously large and the tensioners were perfect so It's gotta be something stupid I'm missing. I'm going to double check the tps when it's not so hot outside. It and the coolant temp sensor are new, maybe one of them are defective.
