kapower06 »
https://forums.nicoclub.com/kapower06-u18983.html
Fri Dec 30, 2005 12:30 pm
I believe to use the SR stuff you have to use sr flywheel, clutch, pressure plate, and starter.... just use a ka clutch kit... I just got done installing my new clutch kit today went very smooth after re-drilling the holes a couple mm's. Not to thread jack but I have a question of my own... When I had the motor on the cherry picker with just the flywheel on it I could turn it over pretty easily then it got a bit harder ( compression) but could still spin it through the entire stroke... Is there a problem or is this usual?
