KA24E CAS question
SSS
I need a picture of the slotted chopper disc inside the distributor of the KA24E as i need to know the positioning of the 4 inner slots on the disc used determining the crank angle position for ignition and fuelling.Why you ask? I need to determine the waveform produced by the optical sensor that is received by the ecu (it goes from 0-5 volts) to determine whether i can utilize a Perfect Power SMT6 piggyback ECU for advancing my timing over stock at certain load/rpm etc.
240nismo
Car: Master of bation
way over my head chief, but if i could understand and help you, i wanna learn how to make a piggyback too.
driftn240
Car: umm, cars, computers, car audio
Interesting idea. I'll try to get you 1 tomrrow. Let me know how it works.
