aurora61 »
https://forums.nicoclub.com/aurora61-u42830.html
Thu Dec 28, 2006 11:03 am
My car died when i was driving. I felt a sudden loss of power, then all the electricals went out, and i had to coast to the side of the road. I tried jump starting it but all the car did was crank.
After that point, i replaced the alternator and battery. However, the car only cranks but doesnt turn over. All electricals work while the car is in the "on" position, but nonetheless, the car doesnt turn over. While its in the "on" position, the car's voltage is around 12 volts.
After doing some research, i found that my problem could be a faulty fuel pump or a bad starter.
I never really knew that the fuel pump area is supposed to humm when i turn on the car, so i tried that...i openned the gas cap and listened while my friend turned on the car but no noise. I also put my ear directly to the fuel pump in the trunk, but no noise. (my gas tank is a little over half full if that matters). The only noise i hear is a humming sound from some part next to the intake manifold. That part seems to be pushing some liquid (oil? gas?) through two tubes, which produces the humm.
As for the starter, i tried hitting it a few times but nothing changed.
Honestly, i dont want to buy both a starter and fuel pump if only one of them is broken. So if u guys can give me some insight towards the solution to my problem, that would be great. And if the problem isnt the fuel pump nor the starter let me know. Thanks guys
Btw...my car is a 1990 240sx with n/a ka24e
