mtnmannm »
https://forums.nicoclub.com/mtnmannm-u81621.html
Wed Nov 21, 2007 5:03 am
I have a 97 PU 4WD. Dealer has done timing chain replacement twice after 15K between, for startup noise. Decided to do myself this time and change to a NISMO 270 cam. First NISMO cam dealer sent, did not rotate freely just sitting in the cam bearings. Figured it was slightly bent. Next cam rotated fine. As things got rotated a bit, had to start timing from scratch. It runs very rough. Timing light shows it to be quite retarded. Mechanically, I think everything is lined up both cam and distributor. I wonder what I am missing? In a few days I'll check everything from scratch. I see from an archived post that a person had put in a NISMO cam and the A/F ratio had to be remapped a bit. Appreciate help from somebody that has done this before.
