240sxfastback »
https://forums.nicoclub.com/240sxfastback-u124981.html
Tue Jan 27, 2009 11:10 am
Alright all you KA24E guys out there I need your help.
Just picked up this 89 240sx fastback and i noticed the cam gear was very worn out.I bought a new cam gear, and decided to see how difficult it would be to take off the old cam gear and transfer the new cam gear onto the chain.
I marked the position of the chain to cam gear relationship,Took this one bolt off,then slid the cam gear off.Marked the new cam gear exactly as the old one, then positioned it where it belonged on the chain.(new cam gear on and now too low to reach camshaft bolt hole)The tensioner is now being a ***** and won't let me line up CAM GEAR BOLT HOLE TO CAMSHAFT BOLT HOLE. The tensioner uncompressed itself- and now the chain is not giving me enough play to be able to meet the holes. The cam gear bolt hole is now lower than the camshaft bolt hole.
Is there any way I can re-compress the tensioner so I can get this MF back on there? Or am I going to have to remove the hole damn timing chain from the engine to do this crap?Thanks!-Noah
