ryandevilhorns »
https://forums.nicoclub.com/ryandevilhorns-u150253.html
Mon Jun 28, 2010 2:39 pm
I had an SR S13 a while back and this is my first go-round with a KA. I got an 89 S13 a few weeks ago and it drove fine for a week or so, but I've had nothing but problems since. I've been driving it a little harder than I normally would because I have two cars right now and I'd like everything to break while I still have that luxury. The car is complying with that for sure.
Day 10ish: Only sign I had that bad things to come were after fixing a taillight problem, I drove a it a few miles; car died getting off the freeway. I was able to get it started and driving home, just hoped it was a fluke.
Day 14ish: Drove to work, co-worker comes in after says I have a pool of coolant under my car. Filled it up with water and drove it home fine, so I thought the rad cap wasn't on tight and the coolant had all rushed out.
Day 15ish: Drove to work again, took a left hand turn a little hot, car loses power and bucks; clutch kick and it steadies again in time to come up on a right hand turn. Make the turn a little hot, same thing. Come up on the last turn before my office and come in a little hot again, same thing except the car dies and I can't get it to start. Got to push it the rest of the way. Come out when it's quitting time, won't start at all.
Day 16-20ish: Took some time to replace the radiator, and some P/S lines that were leaking; partially in the hope that it was shutting off from running too hot.
Yesterday: Got everything back together, starts up perfectly, drive it down my street fine, make a U-turn and the car dies; got to push it back to my house where it sits now.
So cooling and P/S systems are fine now, looking into other areas, my suspicions are:
-replace cap / rotor / wires / plugs; never replaced before; this is my first distributor equipped car.
-fuel pump - The guy I bought it from said that he replaced the injectors, the cover for the FP wasn't fully bolted down and the pressure/return lines look fairly new. I have fuel pressure past the filter though and my unscientific eye sees plenty of fuel being pumped out.
What do you guys think is my problem here?
