ka24e bogs and sounds horrible
carkook
I just replaced the distributor drive gear, and im pretty sure i got the timing right. It will only run in one spot. It holds a clean idle, but wont rev at all. As soon as you give it gas it wants to die. Any suggestions?
rockinthefans
Car: 92 240 hatch running on hopes and dreams
Are you sure the timing is right on? Because it deffinately sounds like its not. I would double check. Not saying you don't know what you're doing but I've been down that road before.
carkook
Well im pretty sure i got the dist. drive gear in right. it was the closest to#1 on the dist. cap at TDC. It wouldnt run at all if i moved it one to the left or one to the right. I also tried moving around the dist. while it was running didnt make much of a difference. What could cause it to only run at idle? Every plug gets spark and ever injector has power.
rockinthefans
Does it seem to idle fine? Did you mess with anything else when you did the dizzy gear?
carkook
Yes it has a steady idle, the spark wires arnt crossed or anything. Nothing really, that invlovles it running anyway. I replaced the water pump and thermostat.
carkook
anyone
Space Monkey
Car: 1990 Nissan 240sx
sound like its not getting enough air/fuel mixture to run faster. make sure you installed it correctly. Double check the spark plug wires are pushed all the way in. Moving the distributor should make a lot of difference though, you should be able to force it to back fire with out killing the engine. I would get a timing gun and make sure its timed right.
carkook
yeah I checked all the spark wires, I think it might be that the fuel pump has died or is really weak, Ill get back to you when I check the timing.
Vegascorbin
Car: 1990 240sx dirt track race car
Are you sure that #1 was on a compression stroke when you put it at TDC?Sounds more like a timing issue than a fuel issue to me.
rockinthefans
Im with him. It pays to double check.
carkook
Well I turned it over untill the mark on the crank pulley lined up with the pin.Wouldnt that mean that the number 1 piston would be at the top of its stroke?
carkook
bump... still got a broken car
zstylelowrider
Car: 1995 nissan 240sx
could you explain why it is that you replaced the distributor drive gear?
carkook
because it broke.... hahaha just messin thanks for your interest
