onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Oct 31, 2005 8:46 am
I think you can answer those questions yourself:
1) What is your time limit (i.e. is this your only driver, you don't have a lot of time, etc)?2) What is your budget for this car to rebuild/upgrade (usually the determining factor)?3) What are your goals?
What exactly "blew" on the ka? If it's just a headgasket, that can be replaced cheap and "easily". You could even swap in another sohc motor for anywhere between Free - $100, depending on how long you wait. Of course, you won't know the conditions of those motors - again, depending on your budget you may either want to do a rebuild, pay a shop or do it yourself, etc.
The Dohc swap is doable and legal if you swap over the dohc emissions & ecu etc, but if you search the threads which also outline it, it is a lot of work if you are just going to be doing no upgrades and just a daily driver, plus it's usually more expensive than sohc motors .
If you need any help, feel free to contact me via email or aim - listed in my profile.
In any case, I should be doing a "mini-rebuild" of my sohc motor this coming thanksgiving weekend if everything works out - I'll do my best to document it well so it will help other sohc ppl. The main advantage of sohc is that it is much easier to work on for a lot of things, relatively.
