ka24e block w/ ka24de head turbo????
stacy
Car: 1990 nissian 240sx se
okay i have an idea ka24e block with a ka24de head turbo is this possible??
ILikeMy240sx
Car: SR Power
I highly highly doubt it. All the oil galleys are probably different and the head bolt configuration is probably all different. What would be the point of this?
stacy
i know that they sell a kit to throw the de head on the e block but the compress is to high to turbo it out.
but im intersted to know if u bor out the block and lower the compression if it would be too low
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
first of all..welcome to ze forumz...second of all ...you will find out sooner or later that good grammar is the key to receiving a decent answer here...it's really hard to care when someone doesn't even put effort into typing.
yeh this doesnt make any sense...it's not like 9.1 compression is atmospheric. you could still add FI to it and retain turbo response at the same time. and it would be very cheaper and wiser to just get a used de, as yours is most likely up there in mileage. and if ur gonna do that ull prolly just look at an SR anyway...hmm i seem to be rambling
Red coupe
Car: 92 Nissan 240sx Coupe
Post KA questions in the KA forum...
Anyways aren't the E pistons flat topped, and create much higher compression ratios with the DE head?
Why you would want a higher compression engine for a turbo build?
ScorchedNX2K wrote:yeh this doesnt make any sense...it's not like 9.1 compression is atmospheric. you could still add FI to it and retain turbo response at the same time.
what are you talking about atmospheric pressure?
dickie
Car: Killer Turtle
moved to ka-t
S13FX
Car: '69 l20b Dimeski :)
Just do your self a favor and keep the heads on the blocks that are made for each other. Its like trying to mate a freaking donkey with a horse. Oh and ScorchedNX2K is correct about the grammar.
crzycav86
Car: 93 Nissan 240SX KAT
Swapping the DE head on the SOHC block has been done before(search the KA forum). However, it raises the CR to somewhere in the area of 11:1, which is too high for turbo on a ka.
just stick to the sohc motor, it's perfectly fine for boost.
WDRacing
Moved to KA!!!
dickie
Car: Killer Turtle
lol, move wars.
WDRacing
Hahaha...I figured you'd see it. I figured the KA guys would have better answers as far head - piston compression etc. My guys over at KAT just want to add boost to everything
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
SWAP the de head for an E head. SOHC pistons use raised dish pistons compared to the DE because the SOHC uses a hemispherical head design.
stacy
Yeah well thanks for the comments guys.
