NISTECH wrote:if the connectors are the same it will work. I believe there is 3 different pulleys for the altenator over the yrs 89-98 240s. 2 different dia V-drive pullies and 1 serpentine drive pully.
The pulley was a little bigger (and I do mean a LITTLE) so I bolted it up, adjusted the top screw (the one you can slide) and adjusted until I felt the belt was tight enough, and it works.
Anything wrong with having a bigger pulley? Would it make the engine work harder/run slower than it would with a smaller pulley? Like I said, it works, I changed the alternator and the battery and the car crunk right up, fast.
