hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Fri Jul 18, 2003 4:50 pm
THe stock rail is for side feed injectors. I dont think you can modify it to use the MSD 50lb top feeders. Most people upgrade the rail to use top feed injectors cause they're generally cheaper than high flow side feed injectors. With the top feed rail, you dont have to modify your injectors again if you have to replace them.
Jay
