ka24e 2 ka24de
edpogi
i got a 89 240sx. and s13 body. had a blown motor and now i put a ka24de motor from the 97 s14. i got the motor in and everything but i cant get everything on the wire harness to fit. is the wire harness from the 91-94 s13 fit with the s14 ka24de motor?
TrunkMonkey
Car: 2000 Lincoln Navigator
iirc, no.
if i'm right, you'll need the wiring harness and ecu from the 97.
-demetrius
edpogi
no i dont need them becuz i have them already. and it has alot of left over wire and is miss the igniter and coil for it. i think the 97 is different. that is why i am looking for the s13 ka24de wireharness.
p00t
u need the wiring and harness from the new engine
it is not missing the coil.... it is integraded right underneath the distributor, hence the need for only 4 spark plug wires. the crank angle sensor is no longer under the distributor, its now on the transmission housing (i think).
edpogi
ppot have you done this swap already? now you know where the wires split into a y? the one that goes to the side. what are those wire for? the one that dont go to the engine.
p00t
sorry :( i havent done this swap, i just know the changes they made from the earlier KAs
the wiring may be alittle different, like different connectors etc. i really think your gonna need a fsm from that car year to get everything working.
