dccse3k »
https://forums.nicoclub.com/dccse3k-u127944.html
Fri Feb 27, 2009 6:09 pm
Okay, so after I finally get a new transmission to buy(another problem lol) i go to start my car and it doesn't work. It cranks and just doesn't start. I have gas, I get spark on the plugs, but don't know how much power is supposed to go to the fuel injectors. A little bit of gas leaks out of the O ring after I crank but i don't know if thats a pressure issue or it just is a leaky O ring.
I Checked voltage from the distributor and it was fine. Checked resistance on each of the injectors and they were all 14 so they should be good. Checked all fuses in the 3 fuse boxes and they were good. I'm thinking its a wire somewhere but can't be sure.
Does anyone know the voltage that's supposed to be going to each injector? If it is 12 i will try hot wiring one to the battery to make sure it works before thoroughly inspecting each wire.
Any suggestions on what to try would be appreciated, thanks for the help
