95_240sx wrote:Whats the point in sleeving a cast iron block?
Rick
The KA is a sand cast block. Due to the nature of sand casting, the cylinder walls may not be perfectly even in thickness at all points. If you bore too much and run high cylinder pressures, it is possible you may flex a cylinder wall. Sleeves ensure there is sufficient wall thickness all around the bore.
Frankly speaking, the slight overbore is not going to net you much in the way of power. Depending on what your goals are you may want to consider not overboring if you can help it.
