Ka flows better than a Sr actualy, it would be a downgrade in heads. An impossible downgrade at that..WDRacing wrote:Won't work. Also, the KA24DE head flows just as well as the SR head does. So there would be no gains from making the swap.
If you were to take a SR20 head with the variable cam timing then maybe that would be worthit. But the bolt patterns and spacing is all wrong, so none of this would work anyway.
WD
