s13_ka24det »
https://forums.nicoclub.com/s13-ka24det-u50657.html
Mon Dec 11, 2006 5:02 pm
Hey everyone,I just finished swapping in a stock rebuilt kade engine (blew piston #1 originally) and need some help. Before the swap, I was running a JWT n/a ecu tuned for 370cc injectors and had a FMU installed on a T3/T4 setup and the car idled fine. I just swapped the engine and now using a JWT turbo ecu tuned for 370cc injectors and stock MAF and the car sputters & boggs at idle (removed FMU). All engine internals are stock right now!Any help is greatly appreciated!
1993 240sx FastbackT3/T4 ball bearing turbo38mm Turbonetics external wastegate (open to atmosphere)FMIC (custom)Greddy Type S BOV (vent to atmosphere)370cc SR20det injectorsZ32 fuel filterWalbro 255lph fuel pumpNGK Iridium plugs (one step colder)Magnecore Ignition wiresBRM 3" catback exhaust (dual tip)Catco 3" hi-flow cat3" down pipeshortshifterR32 VLSD (w/5 bolt axles)S14 5 lug conversionCross slotted rotorsSteel braided brake & clutch linesCeramic brake padssubframe spacersSuspension Techniques sway bar kitupgraded suspension rodsK-Sport coiloversGreddy upper front barOEM S13 sideskirtsKaminari rear bumper add on180sx Kouki spoiler
