Ka24DET surging idle problem (video)
Unstock240
Car: 89 240sx se
Well My KA-T runs pretty good for the most part. When I drive it for about 30 minutes the idle starts to do this: causing it to die as well from dropping too low. What should I check out? Never did this before turbo, and the bov is recirculated.
http://s14.photobucket.com/albums/a305/ ... MG0589.mp4
biggie
How is it tuned?
How is the IACV hooked into IC piping? ECU Temp Sensor been replaced?
Unstock240
Car: 89 240sx se
Running 8:1fmu stock on 7psi is my tune lol.
the iacv is just straight into the coldpipe? and i have swapped ecu temp a few times.
terry_240sx
Car: '93 240sx hatch
is your maf blow through?
it sounds like a maf problem to me,that's what mines did when mines was oily and not reading the right amount of air.
you should try someone elses maf
