ka24det running fine but feels stock!!!!!!!
rb26iwish
Car: 1995 nissan 240sx w/ SR20DET
hey guyz i finshed installing my td40 turbo on my ka24de and everything is working and running properly but its not reading boost in second and third i can sorta feel it but 1rst nothing any idea what could be happenong i would appreciate the help...... i have no idea what it could be... any answer will help
480sx
Car: 1996 Pearl White 240sx
Gotta give us some more info dude.
Soo are you making boost at all?
DevilMB3017
You installed a turbo kit and don't know why it won't make it boost?
Check your vacuum lines, intercooler piping and couplers, and EVERYTHING you did.
rb26iwish
i checked everything over and it all looks good all the piping is connectedand everything is tight and no leaks and it does go in to 20 vaccuum and when i give it gas the needle shakes but does not go in to boost... could it maybe have something to do with clocking the turbo is this a possibility? thanks for the help
DevilMB3017
Is your wastegate on properly? Or is it an internally gated turbo?
When you clocked the turbo, did you tighten everything back to spec?
rb26iwish
yeah i had checked online and def tightened everything back to spec and it is internally wastegate i have no idea what could be ...
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Tug on the wastegate actuator rod, it should be firm, if it's broken it might be loose and not letting the turbo build any boost. Just a thought..
Chaluska
also the blowoff valve may be leaking, I had an 1st gen SSQV that was leaking from the top vaccum nipple. i could build like. 1psi-2psi max on a T25.. replaced the BOV and got my full 8psi back
