pj »
https://forums.nicoclub.com/pj-u25266.html
Thu Mar 03, 2011 2:49 pm
thermostat may not be opening properly, head gasket may be on its way out...are there any coolant leaks anywhere? you may not see the origin but if you see any wet spots on anything you have an issue, if it were mine, id do a few things first.
1, examine everything
2, make sure no oil/coolant is mixing in either one...
3, flush the cooling system, check thermostat (you can use a thermometer in a heated pan of water, make sure it opens)
4, inspect waterpump.
it may or may not be a headgasket issue, just cover all the bases before you go tearing it down.
