nissan240boy »
https://forums.nicoclub.com/nissan240boy-u182547.html
Wed Oct 19, 2011 9:51 am
Ok dude big misunderstanding, im pretty car smart actually, heres how it went, I put turbo on, hooked up oil without a restrictor cause I didnt know bout it, oil poured out exhaust, so I disconected oil and wastegate, so there was no oil goin to thr turbo for 2 days of drivin around and thete was no boost because there was no wastegate, I thought the turbo wouldnt spin at all or very little without a wastegate but I was wrong, after learning bout the restrictor I got one and installed it, then took off.my air cleaner anf discoverd the nut came off the turbine amd kept getting sucked into it and its all marked up and there is magor shaft play, so I decided screw it I hooked the oil up and everything else, also I have sr 370s and emance ecu tuned for my setup and an aem eugo wideband, anyhow I was bored.wating for my new turbo so I put a valve on the incoming oil line to the turbo to restrict it enough that it still somewat lubricated it but dorsnt leak out, then I took it for a drive and boosted 1lb of boost, I think it.boosyed so low cause theres exhaust pressure escaping from between the turbo and downpipe flange cause my gaslet is bad and prolly cause the bearing is work so bad, so to sum it up I ruined my turbo cause I didnt know bout a restrictor and drove it with no wastegate or oil to the turbo and now im just tryin to have alittle fun with my broken turbo till my new turbo comes, also im runing a cx racing wastegate, and I only have 2 ebay parts on my car which are turbo and manifold and the manifold seems very strong, the rest of my parts are aem wideband, emance ecu, jecs 370 injectors, bov of my old turbo ford probe, stock maf, magnaflow cat back exhaust, custom downpipe I made and heat rapped, welded rear I had my grandpa weld.with a stickwelded, full body kit and bodywork and custom base coat clearcoat paint job done by me, also have an autometer boost gauge, stock fuel pump (is stuck pump of for 8lbs of boost on my setup, my valve cover I painted witj flames, I have 2 and a half inch intercooler piping withe a jdm intercooler, so there is me being as thourogh as I can and sry for bad typing im typing on a phone, so I hope that explains to everyone im not dumb and know my stuff but there are things I dont know and I learn on here which is good cause I love learning bout cars so thank you everyone who had helped me, ill try to post some pics of my car tonight
