ka24det problem
duveeka24det
Car: 240sx
My car wont rev pass 4 grand. I know its not my exhaust, because its not restricted its a straight flow to the back. Its like it has a rev limit a 4 grand. It just keep busting up.
eazye2000
Car: S13 KA-DET
Did it jump time?
What exactly happened? Did it just start doing this all of the sudden? Or did you do something to your car, and now it's just starting to do it?
Try to be a little more specific.
Modified by eazye2000 at 8:43 PM 2/6/2007
WDRacing
Gonna need to know your entire setup man. Hard to troubleshoot from the bench if we're blind and have our hands tied.
Are you sure it 4grand and not say, 2500?
WD
duveeka24det
Car: 240sx
I have a t3 turbo with xs wastegate and a hks bov. i have a manual boost controller from ebay. I have the bov and the boost controller t'ed into a vaccum line on the side of my intake manifold. Right under the throttle cable. and the other port on my boost controller goes to my waste gate and the top is left open. My engine is stock. I removed the egr valve and its running a little better. I dont know what to do with the vaccum hose that went into all that. Do i just block it off? my car will rev up fine in neutural but when i put it in gear and floor it it takes off and then starts busting up. Does it matter which hose goes on top and bottom of the boost controller.
9sec240
Car: S14.5 Turbo KA
What do you have for fueling? pump? injectors? What are you doing to control fuel? SAFC? RRFPR? EMS?
duveeka24det
Car: 240sx
Some one told me i could have my boost turned down for right now untill i got new injectors. Why do u think thats whats causing this problem
9sec240
Car: S14.5 Turbo KA
duveeka24det wrote:Some one told me i could have my boost turned down for right now untill i got new injectors. Why do u think thats whats causing this problem
Yes. You need at least a Walboro fuel pump and RRFPR or SAFC to get a basic tune in it. You will also need to back your timing off. Be careful, you about to blow your motor up.
duveeka24det
Car: 240sx
Thanks man! What parts could i use off a 300zx i know that the twin turbo 300zx injectors will help me out, but can i use injectors off a non turbo 300zx or a fuel pump or something. What year 300's could i take parts off of?
WDRacing
How much boost are you running?
WD
duveeka24det
Car: 240sx
five psi right now
9sec240
Car: S14.5 Turbo KA
I have heard that you can run small amounts of boost with basically stock engine management but I have never done it that way.
At a minimum, you will need a good fuel pump. Walboro 255L HP would be perfect. A 300zx TT fuel pump would also work fine.
A SAFC on top of that would be ideal as you can dial in your air fuel ratios for when your in boost.
WDRacing
I give the the distributor a little twist of retard just for safetys sake.
PapaSmurf2k3
Site Admin
WDRacing wrote:I give the the distributor a little twist of retard just for safetys sake.
Which would be clockwise IIRC.
9sec240 wrote: Be careful, you about to blow your motor up.
I LOL'ed
duveeka24det
Car: 240sx
My friend has a fmu, u think that will help me? Its 12:1 though.
WDRacing
12:1 will make it rich, but its better then running lean. You can swap out the rubber disk for a 10:1 FMU and be running a decent AFR. Just keep the boost at or under 8 PSI until you have a method of retarding timing on boost. I'm selling a Brand new Vortech 10:1 FMU right now for $50 shipped.Email me at [email protected] if you're interested.
WD
duveeka24det
Car: 240sx
I installed a fmu on my car today the 12:1. But my gauge is still saying lean. I looked at my ox sensor and the wire on the top was almost ripped off. Would that make my car still run lean. And im also wondering if my friend hooked my fmu up correctly.
WDRacing
Are you using a wideband O2 or narrow band. The narrow band is only good for idle mixture.
duveeka24det
Car: 240sx
This might sound stupid, but i honestly dont know. Its the stock one off my car if that means anything
duveeka24det
Car: 240sx
This web site has help me come a long way. I only have one person helping me. I think im the only black guy thats into imports in my area. All the rest of my friends are worried about big bodies with big rims lol!
WDRacing
I meant the air fuel gauge. Do you know if its a narrow band or wideband? How do you know its lean?
duveeka24det
Car: 240sx
I dont know its a faze air and ratio gauge. When it idles its on lean the highest lean bar. When i get on the gas it takes off fast then sputters and if i let of the gas a little bit it takes off a lil faster.
nissanfanatic
Car: 1992 Nissan 240sx SE
ITs a narrowband.
If you are running a 10:1 with a Walbro, you aren't running lean.
duveeka24det
Car: 240sx
i have a stock fuel pump and a 12:1 fmu
nissanfanatic
Get a Walbro and rewire it.
duveeka24det
Car: 240sx
I will, but I think its cause of my o2 sensor. the wire broke off the top of it yesterday.
nissanfanatic
Your narrowband has nothing to do with it... It only affects part throttle operation. I have driven with it completely disconnected and I didn't realize it until I was 15 miles down the road and looked at my wideband...
duveeka24det
Car: 240sx
Damn! I cant believe I was that dumb LOL!I blew that engine last year..... My first turbo project ever.. It lasted for about six months.I was young and stupid... A lesson for new beee's tune it or lose it...
WDRacing
duveeka24det wrote:Damn! I cant believe I was that dumb LOL!I blew that engine last year..... My first turbo project ever.. It lasted for about six months.I was young and stupid... A lesson for new beee's tune it or lose it...
I would have left it in the archive man...now everyone is going to how WETODDID you are...lol.
duveeka24det
Car: 240sx
HA damn! there is no turning back now...
