GM made an electric vac pump from 94 - 96 on LT-1's. Im gona find a wrecked vette and see if i can snag one to mess with.
I still think my PCV system kicks *** though.. Three lines running to a catch can. Two from my valve cover, and one from the stock PCV valve. From the catch can to the pre turbo intake. Its already been battle tested and worked incredibly, i pulled a half pint of black gas with no oil out of my catch can when i had a cylinder running rich.
From the little research iv done i have gathered that you will actually see some gains by having your crank case under vacuum. The theory being is that it pulls the rings out against the cylinder walls as much as possible and increases the seal.
The only downsides i have seen so far is creating to much vacuum which can suck out oil(this can be avoided by using the stock oil separator). The other downside(this one seems far fetched..) is that to much vacuum could suck out the oil from the rod bearings.
The other common method used by drag guys is to use the exhaust/down pipe as a vac source.
Two good threads on PCV theory and setup.
http://www.dsmtalk.com/forums/...30210
http://forums.evolutionm.net/a....html
