nissan240boy »
https://forums.nicoclub.com/nissan240boy-u182547.html
Thu Dec 15, 2011 9:38 pm
i turboed my ka24de and works good, except idle is horrible, when i start it up and its cold it will idle ok at 1500 for 10 seconds then just s*** off unless i keep my foot on the gas, sometimes itll run for a little if i let off the gas pedal but the idle jumps up and down big time and eventually shuts off. now ive checked everything, i dont think its the injectors cause it tries to idle when its cold, i did a leak test and theres a little leak but its very minor and i fixed the major leaks i had and it made no difference. anyhow heres wat im wondering is causing it i cut the metal pipe going to the manifold from the egr when i changed manifolds and its just open to clean air, also i removed the other exhaust recirculation thing for the exhaust and intake air that sits on the drivers side near the power steering resivoir, could either of these two things be causing my idle issue and how can i fix the idle, because before i turboed it and did all the work the car idled perfect. now ive read the idle threads and fully understand it but i have a bigger problem, because to adjust your idle the engine must stay running which mine wont without keeping your foot in the gas pedal, so please help me out here, thank you
