KA24DET, is it really worth it?
Lukeskywalker
Hey! I was researching the KA24DET engines and have heard many people say that these engines are not meant to be turbo charged and often result in detonation and other malfunctions. Are these modifications worth the money? I really want a 240, but dont want to have to worry about not having a reliable daily driver.
PLEASE SHARE YOUR KNOWLEDGE!!
Zippy69
Car: 1993 240sx coupe
Do some searching here and you'll find out that that crap just isn't true. If not, just go buy a honda. There are many members here with daily drivers making 300+hp with no problems.And when something does happen, there is usually a reason, like bad tuning or some other reason that was not a problem with the engine just the operator.
quick_blaze
Car: S13 240sx Silvia
It just depends on what kind of setup you run. there have been many problems with some KA-Ts but there are lots of problems with a lot of other cars as well. just remember that many people who go KA turbo are looking for a cheaper solution to a swap. The ones who have problems will usually be the ones that were very cheap and poorly done. the engine was not built to be boosted but many engines werent. but just like any honda, if you do it right and dont take the cheap way out by using crappy parts, you can have a very reliable build. many people are running around with 300whp on stock internals with the KA. just build it well, and get a VERY good tune, and you will be set!
Florida240sx
They fail because of cheap parts/bad tune/not enough supporting mods like fuel or too advanced timing
taco_401
Car: 240sx
any motor can be boost it just depend on time and money you put in it o yea lots of research lolz
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Florida240sx wrote:They fail because of cheap parts/bad tune/not enough supporting mods like fuel or too advanced timing
plus the way you drive your ka-t
WDRacing
Read the FAQ at the top of the KAT forum.
