Although I'm not well-versed in the realm of KA-T setups, yours is questionable even in a general sense. Why is an SAFC involved when the ECU has been chipped already? The MAF and injector parameters should have been put on the chip....or
was chipped at all? The blow-through MAF is also a big can of worms all by itself; it's usually done to overcome atmospheric flow limitations of an undersize MAF. You're also stuck taking the PO's word on what your injector size actually is.
r3b wrote:
Before I did all of that ^ I initalized the safc which basically the engine reads normal off the ecu. When I did this the rpm would jump down to low as 700 and go high as 1300. It would settle down after 5 minutes but you could smell very dark and rich fuel around the car. My air/fuel gauge would also jump around with the rpm as well and would go low as high 14s and even touch sometimes 20...
That suggests to me that the ECU is still set up for smaller injectors. The 20:1 AFR is indicative of a misfire, not what the AFR actually was. Lean misfires and rich misfires both show up as a lean condition on a wideband.
I think there is also something wrong with how the previous owner has the turbo setup since if I try to give the car some foot I could hear the turbo spool but I could never get anything past 0psi of boost, the gauge only shows the vacuum pressure and when I put foot the gauge stops at 0psi. IIRC the guy told me his wastegate is set to 6psi and hasn't touched his manual boost controller to add more boost to the car.
Where is the boost gauge tapping a signal from?
His set up goes air into turbo with no filter, air goes into hot pipe where the BOV sits, then the air goes through the FMIC, then exits to the cold pipe where the MAF is and then goes to the engine intake. Normally I would see in setups that the MAF would be before the filter and then to the turbo. Then the BOV was on the cold air pipe on the other side of the car.
One benefit of running the MAF downstream of the BOV is that metered air isn't venting to atmosphere and won't screw with the mixture...
Another strange thing about the previous owners setup was that he had 720cc injectors.... Ive seen similar ka-t builds and the highest ive seen for injectors was 550. Do you think that having such big injectors is dumping way to much fuel into the engine and is running way to rich and causing to idle like s***? I think that could be an issue and also might be a vacuum leak somewhere. I dont know exactly what he asked for when he shipped his ecu to be tuned but I could give a list of all the parts he put on. Any sticky threads on tuning I should read or turbo building on a ka would help tons. Ive only found a couple basically saying setups but no details the process of installing and tuning the car for the turbo.
Large injectors alone are not a problem, but the tune for them is. Unfortunately I think you need to do a lot of backtracking in order to verify what the PO told you vs. what was really done.
