KA24det IDle problems
s14inwashington
I have a 96 240 SX SE with custom turbo kit. no vacuum leaks, tried MAF in charge piping and MAF before turbo inlet. right now it is before the turbo inlet. Idles like **** when cold, fine when warm. Why does it want to hesistate and die? my BOV is open atmosphere. and i would like to keep it that way, and im running 5 lb so id like to use the KA MAF also. I searched the forum but couldnt find a straight answer. ALso, where should the 2 hoses that normally go to the OEM plastic intake pipe go? one is for EGR and the other is the valve cover breather. If it means re routing my BOV to the intake after my MAF but before the turbo, then so be it. but until then, i want to know if anyone else has a solution to my problem thanks!
WDRacing
Make sure the BOV isn't leaking at all....then get back to me...
s14inwashington
nope, 110 percent not leaking
C-Kwik
s14inwashington wrote:I have a 96 240 SX SE with custom turbo kit. no vacuum leaks, tried MAF in charge piping and MAF before turbo inlet. right now it is before the turbo inlet. Idles like **** when cold, fine when warm. Why does it want to hesistate and die? my BOV is open atmosphere. and i would like to keep it that way, and im running 5 lb so id like to use the KA MAF also. I searched the forum but couldnt find a straight answer. ALso, where should the 2 hoses that normally go to the OEM plastic intake pipe go? one is for EGR and the other is the valve cover breather. If it means re routing my BOV to the intake after my MAF but before the turbo, then so be it. but until then, i want to know if anyone else has a solution to my problem thanks!
Make sure all your hose connections are tight.
As far as the two hoses, they should be for the valve cover and the Idle Air Controller(not EGR). For the valve cover connection, connect it to a point before the turbo. You don't want to pressureize the inside of your motor and cause oil leaks. For the idle air controller, connect it after the turbo or it will be come a source for boost to leak out of.
s14inwashington
so is the problem the idle air controller hose? it has vacuum.....do i tap into the charge piping for this one or put it after the MAF before the turbo?
s14inwashington
one more thing- WHere does the small vacuum hose go? i have that going into the atmosphere also..... it goes into the stock air intake system
cdigity
those hoses have to go to the metered side of the mafafter maf , before turbo inleti had same problem and that fixed iti also have a kat w/ open bov
