nissan240boy wrote:When I think bout it my opinion is 8 lbs of boost is 8 lbs of boost no matter what turbo creates it. If u have 8lbs in the intake you have 8lbs in the combustion chamber so how can different flow rates make any difference if in the end u still get the same pressure from the turbo. The wastegate stops the pressure from rising. The only difference I can think u could get between different turbo's is lag time and maximum boost pressures that turbo can create.
Here's why flow rate matters. Imagine a bicycle tire and a car tire both inflated to 50 psi. Even though they're both at the same pressure, there's physically alot more air molecules in the car tire than the bike tire. So lets relate that to turbos. A t25 vs a t4 lets say. Both can be set to 10 psi, but the larger compressor can move more mass of air at the same pressure than the small compressor. So it's like filling up the engine with air with a shot glass, versus a bucket.
If you have a small displacement engine with small cylinders, then lower flow is useable. But if it has large cylinders, then it needs more air, at the same pressure, to fill them. So a small flow turbo, on a large cylinder car, even set at high boost, may not be able to fill the cylinders efficiently. And a large flow turbo on a small cylinder car may over pressurize the cylinders because although its still the same pressure, its a higher volume of air being forced in, which can cause problems.
Imagine trying to use a regular air compressor to run boost. A regular craftsman 5hp compressor can easily output 30 psi. But not at a volume of air that will do any good. Same idea.
Hope that made sense
