dppflyinhawaiian wrote:im looking to get 300hp daily and 450hp max. do i need to upgrade to water pump, oil pump, fuel pump, etc.
what size fuel injectors should i use? 550cc im thinking
Since your goal is 450 max, it would be very, very wise to upgrade your cooling system. In increases the overall efficiency of your car. Stock water pump, koyo radiator, and whatever fan/controller setup you prefer. I have used a couple, im stuck on the duel 12 inch FAL fans and a DIF duel fan controller. Taps into the OEM CLT sensor, good stuff. You dont really NEED to on a sub 300-350 build IMO, but its always a good upgrade.
Oil pump should remain stock. There are no viable internal oil pump upgrades at this time. If your current oil pump is OK and doesnt have more than around 150k miles on it you can just use the one you have.
Water pump should be taken off, and checked out. If it spins freely without much resistance, go to the nissan dealer and buy a new one. OEM only on stuff like that unless your doing something really oddball.
Fuel pump, upgrade without a question. Warbro 255 is a cheap and easy drop in upgrade. Good till 550 hp i believe at stock FP i believe?
If your going for a rom tune, i would always recommend 850cc injectors for almost every build that has even the slightest chance of you wanting 'headroom'. 450 hp is more than 550's can handle anyway.
