Shusaka »
https://forums.nicoclub.com/shusaka-u119906.html
Fri Jul 30, 2010 9:05 pm
that would be a solenoid of sorts for some emissions s***, i just did a full tear down and cheap rebuild of my KA, i had your same problem at first, i blew my headgasket and the water pump passage seal in my front timing cover, didnt think about the timing cover problem, just did a head gasket, and it never started again, i pulled my valve cover to check cam timing after about 20 mins of cranking and there was coolant in my head already, so i pulled my motor and did a full emissions/ vacuum line removal, and thats what that little "block"/solenoid is for, vacuum emiisions regulation, sorry bout the long post, but triple check your cam timing and 4x check your dizzy, after my rebuild mine once again wouldnt start, i stabbed the Dizzy a tooth off. a good way to check is to unbolt your dizzy, but leave it "installed", have a friend crank your car while you twist the dizzy 180* forward and back, if your compression is good, it should at least try to start while your twisting it. Also check compression on all 4 cyl, mine was #1 80psi; #2 90psi; #3 75psi; and #4 100 psi, it took like 2 mins of solid cranking with proper timing to get it just to try and start, i know i need a full rebuild lol, but if your compression is as bad as mine, your Timing must be 100% correct or nuttin will happen except thrown tools and lost faith in a KA
