Ka24de wont rev up MAF ISSUE???
wdyrland
Car: 1990 nissan 240sx
I did a ka24de swap into my 1990 240sx because i warped the head. The engine will idle decent other than running a bit rich. it wont rev up past 2500 rpm. it seems like a rev limiter.
i bypassed the sensor and the car would rev up but would not idle running exremely rich. so i went and got another maf from a nissan maxama with a ka24de to see if that would fix the problem. but nothing could it be anything else i am stumped.
i dont think this would be a problem but i got a cold air intake and its got a dent in it near the end.
any ideAS would be great, i am going to get another MAF to make sure.
jrad240sx
Car: 1990 Nissan 240 SX
did you set timing back on the mattin marks and colored link chains?? cams and idler sprocket? distr. could be off a tooth.
wdyrland
yeah i checked all that and everything is good and timed properly
wdyrland
any suggestions would be greatly apprecated. it has been like this for 6 months sitting in my garage
dtuner
Car: 95 Nissan Maxima (full R34 front conversion)
try advancing the timing a few more degrees before TDC. My 2TC was starting to have the issue when i increased the fuel and air flow, but then i just had to take the timing before TDC more, and she runs well now. Any mods other than the swap? Are you using the DE ECM or the E ECM?
wdyrland
okay i will try that . The only mod on the engine is a cold air intake other than that it is stock. Also i am using the Ka24de ECM
wdyrland
I checked the timing on the car and it is timed. when i un plug/ plug in the MAF nothing seems to change aND it still wont rev up. when hold t around two just before it "governs" out it is very sputtery. could the MAF wiring be grounding out or not recieving a ground? it will rev up if i bypass the sensor but it just overfuels because its getting a full signal. any help would be greatful
wdyrland
bump
jrad240sx
Did u ever get it figured out
