KA24DE won't run idle problem!
ucantstopthebick
Car: 1992 Nissan 240sx KA24DE
hey everyone my girlfriend just bought a new car is a 93 altima but its got the fwd ka24de.. its not running at all if you press on the gas it will bog down and die... and when you first start it it will idle but jump around from 700 to 1000 for a few minutes. after that it will start up for about 3 seconds then die.. the plugs are dark and oily and it smells like gas like its got too much fuel. anyone have any idea why this is? i've been checking for vaccuum leaks and maybe a bad fuel pressure regulator...i don't know what else..its not throwing codes... any ideas?
dkdeleon68
Car: 1991 240
check the injectors to see if they are pulsing with a noid light.
180fan
Car: 89 fastback
I'd take a look at the tps. Unplug it and see if it runs in a more stable state.
