onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Sat Apr 18, 2009 12:51 pm
Yes, it's in safe mode.
Most of the time, if the car is rev limiting @ 2500 RPM or so, it's the MAF. And as you said, you pulled ECU codes and got MAF sensor.
After you replaced the MAF, did you pull codes again to make sure it went away? Could also be related to the MAF wiring.
Considering you just bought the car, it could be a lot of different things. Check to make sure base timing is correct, check the distributor cap/rotor, check the spark plugs, spark plug wires, fuel filter, air filter, o2 sensor. Half of that list would just cause poor drivability/idle, but you might as well make sure everything maintenance wise is up to par.
Wouldn't hurt to do a compression test either.
