Schassis/raw »
https://forums.nicoclub.com/schassis-raw-u220140.html
Fri May 31, 2013 4:21 pm
Ok so I've been trying to figure why my ka24de won't accelerate if I press slowly it seems to be fine but if I press hard it will just pop and sputter and I've checked the ecu the codes its throwing are 34 and 45 not sure the deal with the Ks is but the leaky injector dosent make sense I took out the rail and turned the key to 0N to prime the fuel pump but there were no leaks and the injectors are only about a year and half old haven't had a problem with them this whole time my afr is reading weird numbers as well at idle is like 10 and sometimes in full rev it stays at like 20 wtf has anybody had a problem like this before plz help if so
Mods done flywheel / clutch , walbro , hotcam , cold air intake , blaster coil
