KG300ZXTT »
https://forums.nicoclub.com/kg300zxtt-u127967.html
Tue Apr 14, 2009 6:02 am
Hay I have a KA24DE that will not idle. I got the engine from a friend (he got a sr20) the engine ran strong. After we swaped we had problems to get it running. The ignition good injectors good resistance no check engine light or everything. Car starts but stalls all the time checked the following
ECU Have 2MAF Have 2TEMPERATURE SENSOR NewCOIL GoodSPARKPLUGS NewPLUGS NewROTOR CAP GoodVACCUME No leaksEGR Removed completlyFUEL PUMP New Walbro 255
NO FUEL LEAKSIGNITION GOOD
I JUST GOT IT TIMED NOW IT DON'T STALL BUT IDLE IS VERY IREGULAR AND AROUND 1500-2000RPM
next i will check fuel pressure
Also i need some info on
How to check MAF resistance and what should it beWhats the resistance on Idle Control Valve
I Know it looks complicated but if u have any other suggestions let me know
