KA24DE water pump KA24E pulley / power steering pump delete
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
I'm making this thread in an effort to stop the spread of misinformation. I found this link:
http://www.club-s12.org/forums...22918
The belt part number (GATES/GOODYEAR: 4030280 / 280K3) on there seems to be incorrect. With that number, the belt is significantly loose and i sure as hell wouldn't rely on it to spin the water pump.
I have seen other people on NICO use 275K4 and cut a rib off. That seems a little better. I'm off to the auto parts store to see if i can get it to work.
ST240
275K4 works like i said above. What a b**** to get it on tho. Pretty much have to jimmy the bastard on by spinning the crank.
a_ahmed
Car: 1991 240sx fastback
i was searching for ka24e water pumpy pulley actually i mean aftermarket aluminum one... does anyone produce one? The only pulleys i could find are ka24de ASP crank pulley. That's great but what about the other pullies..?
I would need ka24de crank pulley (ASP got that cover as does unorthodox racing) and alternator ka24de and water pump ka24e pulleys. I don't need powersteering as I will be eliminating it obviously.
