...and the cams. Truck cams have different profiles from what I have read.seang wrote:Here are some specs: ka24e: truck version= 134hp @5600 rpm & 152 lb ft of torque @4400 rpm.
ka24e: 240sx version= 140hp @5600 rpm & 152 lb ft @ 4400 rpm. (The only difference between the truck and 240 versions of the ka24e is the intake manifold.)
breadbox wrote:240sx motors are front sump, so you would have to make it rear sump.
ecu to match the motor.
Injector timing is different. TBI vs. TPI. TBI injects earlier, TPI injects at the last possible second.Ghost518 wrote:so basically i can get ~6hp if i swap mani's from that old motor outta a friends 240 sitting in the corner?
Sweet.
Truck ka24e has SFI with 4 injectors, just like the 240 version. You can swap the manifolds. Its the older naps-z that has TBI. I have the stock mani on my truck, and while it has 134hp instead of 140, it isn't really that bad. It can still rev past 6000.Drift21_Hardslider wrote:
What's with the odd looking air filter box? Looks TBI (not saying it is).seang wrote:
Well, dang it you KA guys suck!seang wrote:Its a downdraft TB, so I can see how, (from the air cleaner), how it looks like a TBI, but the injectors spray right into the intake ports.
