ka24DE vs ka24DE
nofrey
Car: 91 240sx
does anyone know the difference between the 91-97 ka's?besides the cams...
and are parts interchangable?
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
Differences:
-MAFS (91-94 MAFS not interchangeable with 95-98 MAFS)-ECU -OBD I vs. OBD II- Cams (obviously) only the '91 had the more aggressive ones. either way all the cams are interchangeable
all i can think of right now. feel free to add on anyone!!
98koukile
Car: 1998 Nissan 240SX LE
The intake manifolds are different and the distributor is also, I know you didn't include it but the 98 has a single timing chain instead of the standard double. Also there are some electronics that are different
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
98koukile wrote:I know you didn't include it but the 98 has a single timing chain instead of the standard double.
Whoa for real??? I didn't know that. Are you sure?? That sounds kind of wierd, how does the chain drive the distrubutor then?
vancouverbc
Car: 1991 240sx
coolant temperature sensor changed at some point after 94
480sx
Car: 1996 Pearl White 240sx
The chain doesnt drive the dizzy, the idler sproket does.
Also, the 98's did have the single timing chain, for whatever reason...
nofrey
Car: 91 240sx
hey thanks for the help guys....kinda new to the 240 scene.just trying to get all the info i can
