KA24DE Valve shims?
grannyknot
Car: '91 Nissan 240SX
I just got my KA cylinder head back from the machine shop, he managed to save the valves while re doing the seat and guides but now 13 of the 16 shims need replacing. I have done some hunting on the net but not having much luck finding any.
Does anyone know where I can purchase new or used shims?
I'm looking for,
1 2.00mm
3 2.04mm
1 2.06mm
2 2.08mm
2 2.10mm
4 2.12mm
Thanks
NukeKS14
Car: '95 Nissan 240SX SE KA24DE-T
AC Cobra Mk IV Rep.
2020 Honda Civic Si
Used - junk yard or anyone selling a KA for parts
https://frsport.com/search?q=13229-54F
https://www.courtesyparts.com/?mid=0&pa ... rch_in=all
FR sport has a couple of sizes that don't match what you're after, but damn are they expensive. Courtesy lists the part # but you have to decode them and they aren't listed as in stock... maybe call and see if they have what you need? Get the larger ones and plane them to size? That's still going to be a pretty penny. I'd vote going to a junkyard and looking for Altimas with the KA, Xterra from 00-04 had them, and Frontiers from 89'-2016. I tried searching for Frontier valve shims but hit a wall there, might be your best bet though.
The machinist who did my head didn't have to change shims on a 3-angle regrind and BC cams upgrade so I guess I lucked out. Best of luck man. It'll feel great once you get it back together and start it up for the first time.
grannyknot
Thanks Nuke,
I did find these guys in Australia, https://www.ebay.com/itm/31mm-Valve-Tap ... 1438.l2649
Combined probably just as expensive as having the machine shop skim the difference off the top of each valve so I can use the same shim. Obviously not a Nissan product and there are some big jumps in the thicknesses but I think I can make it work.
NukeKS14
AC Cobra Mk IV Rep.
2020 Honda Civic Si
Choice #3, since it looks like it might be getting pricey. Convert to Supertech buckets (shim under bucket) and use their shims.
https://www.supertechperformance.com/p6 ... m-follower
https://www.maperformance.com/products/ ... ess-varies
^On the lower link there is a dropdown for their shims ranging from 1.35 to 2.70mm in .05mm increments.
