ka24de underpower?
ilovemy240sx
Car: 91 nissan 240sx
hello everyone i have a 91240sx and my problem is i have no power!! its not running right..it sounds really loud but its not pulling, also i cant burn out. when i step on it from a start it bogs a bit then it grabs on, but still feels really slow! theres also a hiss coming out of the engine bay when im driving. please help!! im thinking its my fuel pump, or fuel injectors? but idk.
Razi
Car: Moo
I would check for fuel leaks and vacuum leaks.
Check under the hood as the car is running for any leaks.
ilovemy240sx
ok will do, will compression have something to do with this, bc i did compression check and it was normal
Gogach
Car: 240SX
How to check vacuum leak?
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
good way to do it..buy a can of starter fluid..and spray a tad..not alot at each vacume connection/hose..even rub some on the hose if ya can..do each hose seperate if ya can..listen to the motor..if it reves up high..you have found a leak.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
check your timing/advance and spark as well. Fuel pressure and vacuum signal to FPR
