hatekas »
https://forums.nicoclub.com/hatekas-u197296.html
Sat Jan 21, 2012 12:55 pm
Car is a 91 240sx with a 91 KA24DE
Alright ill just get right into it and begin with the actual problem.
When i start the motor it just revs BY ITSELF to around 4-5k until i turn it off.
the problem began when we swapped the motor. first it ran on 2 cyl, choppy idle, sounded like a boxer and shot flames. After that was sorted out and it was running on 4 cyl's (timing, new dizzy, and sparkplugs) the idle was still VERY choppy. when cold if u gave a little gas it would stall. but when warm it would hold idle but was very unstable and shook the car.
*I have removed a bunch of emissions stuff.
-PCV (clogged holes in upper manifold, valve open and VTA)
-EGR removal
- Butterfly removal (left the rod inside, and left the swirl valve on but unhooked it)
- AIV removed (no tube going into the black box)
So, i went back online and started looking at a bunch of different forums about emissions removal to see if i had missed anything. Turns out i had forgot to clog the vacuum line from under the throttle body that goes into the manifold. ( if im not mistaken its the "purge" line? from the carbon canister)
The "CV" line is still hooked up.
After clogging the line and putting everything back together the motor just revs by itself as i explained before
PART INFO
New o2 sensor
new NGK sparkplugs
new dizzy
Timing has been addressed.
Please let me know anything that will help with getting this swap over with. It was my first swap i have ever done and has been nothing but problems.
Sorry if this has already been reviewed but i couldn't find ANY info that would correspond with my problem.
